specialized 2021
  1. D
    Other M-2 700wh new battery already has a charge cycle
    I bought a brand new m-2 700wh battery from a specialized dealer and it had a charge cycle on it already. I’m not sure if this is normal maybe a test charge from the factory? The thing is the 500wh battery that came with my 2021 turbo levo that I just bought didn’t have any charge cycles. Anyone...
  2. 7
    2021 Specialized Levo SL Expert for SALE
    Hi guys, Reluctantly I've decided to sell my 2021 Specialized Levo SL. Apart from the dropper post and cranks, this is a full custom build. Specification and pictures are below: 2021 Specialized Levo SL Expert - Full carbon frame, SIZE LARGE, with Range Extender, adding 50% more range 2021...
  3. Smeer
    Levo Gen 2 Issues with Fox 36 on 2021 Levo
    So I got a new but second hand Fox 36 fork which I was planning to have my shop install on my 20201 Specialized Levo Turbo which came with a RockShox 35 29, DebonAir spring, Motion Control damper, 51mm offset, 15x110mm thru-axle. I had asked the shop before hand if that fork would work, they...
