norco vlt
  1. Jeremybub
    2025 Norco Range VLT BOSCH SYSTEM
    Hello all just to give you a heads up on my experience with getting a range extender program to my 2025 Norco Range VLT Bosch system First, I had to take it to the LBS and they had to submit an order to Bosch and Norco to update my firmware, allowing the range extender compatibility, this took...
  2. D
    Looking for suggestions on SL style Mid-Travel bike
    Hey guys, Been lurking on the forums for a while now and the time has come to purchase an e-bike! I’m looking for something in the lightweight variety and have narrowed it down for a few options. Fluid VLT 140, Transition Relay, and Devinci E-Troy Lite. I was dead set on getting a Relay until...
  3. O
    2022 Norco Range VLT
    Anyone else having the intermittent no power issue with their 2022 Norco Range VLT? Bike sometimes will not power on and you have to plug back into the charger to reset something and then the bike will power on. It only happens some times but is really annoying. Nothing worse than driving to...
  4. R
    Creaking Shimano Micro Spline solution
    Hi guys If you experience annoying creaking from your Shimano Micro Spline hub there is a simple solution for this. Take a look at these video. 1. Identifying the sound and solution 2. Instructions My hub is now silent. Just needed greasing as it was bone dry. Btw: if you by any chance...
