Hi all, the bearings need replacing in my allmtn7 carbon rocker. I have the tools to extract no problem, however the uneven carbon shaping of the rocker means their is no way to evenly apply pressure when fitting, the press shell will touch a very small area, and obvs Im concerned about the...
Evening all,
Next issue on these bikes! - If you're on the Haibike UK owners group on facebook then you will already be aware of this.
Check all your linkage bearing areas for cracked paint approx 3-4 mm's around the outside of the bearings (2 by the rear wheel axle and the 2 just behind/below...
