fox 36
  1. S
    Levo SL Gen 1 Specialized Levo SL2 - shock Upgrade
    I want to upgrade my fox rhythm to factory series. Do I need the e-optimised version or is standard shock suitable given it’s an SL?
  2. Denver
    Assembly frame LightCarbon LCE971 bafang M510 (By Denver)
    It's time for me to assemble my new bike. I will gradually provide assembly updates with my various critiques of the equipment I've chosen. In a few lines, here's what I can tell you. I rode a "Frey AM1000 EX" and enjoyed using it for 2 years and 2500 km. However, its noisy motor, unnecessary...
  3. SparkleHedgehog
    Fox 36 upgrade to 160 from 150?
    So am I right in thinking the fox 36 performance forks of 150mm on my 2020 turbo Levo carbon expert use a 34 air shaft due to the fact it’s an ebike? I read that ebike fox 36 uses 34 and if so can I just buy this Fox 34 160mm air shaft to turn my 150 forks into the widely regarded better 160mm...
  4. H
    Answered Shockwiz compression ratio
    HI, I have a 2020 Cube Stereo Hybrid 160 with Fox 36 ebike fork (170travel). If i remove or add any volume spacers, will this change the compression ratio ? I find it hard doing the shockwiz calibration so it would be useful to just enter my previous ratio and not go through the entire...
  5. Fox 36 160mm 44 offset vs Rock Shox Pike 150mm 52 offset
  6. Fox 36 160mm 44 offset vs Rock Shox Pike 150mm 52 offset
  7. Fox 36 160mm 44 offset vs Rock Shox Pike 150mm 52 offset
  8. Fox 36 160mm 44 offset vs Rock Shox Pike 150mm 52 offset
    Fox 36, 160mm, 44mm offset, Rock Shox Pike, 150mm, 52mm offset,
  9. R120
    Back in black . . .
    I got a bit carried away with my E-Sentier, originally bought as a winter hardtail as you can see its ended up being something a little more extreme. Went from this
  10. Mambat
    My Specialized Turbo Levo....
    Hi All I am new to the forum... I thought I would add a couple of pictures of my steed! It started life as a basic 2018 Levo Comp, this was my blank canvas :) Upgrades: Fox 36 Fork Cane Creek Dbinline Coil (550lb Spring) Trp Slate GWin Brakes XT 1x11 Groupset Lyne Components 150 Dropper...
