Does anyone know the size of the dropper post on a medium bullit? I have one on order and I want to buy a rockshox reverb dropper to swap when it show up
I just bought a used eZesty, and the dropper post need some service.
However… it does not seem to be a “normal” shock pump valve.
The threading on the valve is internal?!
Anyone know what kind of adapter I can use? And where to buy it?
So I have very very long legs for my height (6'1). I love to have the bike seat slammed to the frame when fully dropped as it makes the bike so much more manueverable. But then I have too much leg angle bend.
Anyway I'm pretty sure my stock Large M20 came with the 150mm dropper post. Not being...
Could it be a cable issue? I am told the actual pressure valve inside is not serviceable and once it goes its new dropper post time.
Anyobody elses dropper sticking, all seals have been cleaned. Seat was also dropping under body weight pressure so I adjusted the barrel screw which fixed it but...
Hey
So finally taken receipt of my 2020 Comp. Its stunning.... I can’t really ride it though... the dropper post won’t hold my weight. I’m only about 70kg’s so not like I’m testing it. I can even push it down with my hands and a bit of weight on top! The lever works as it should but the dropper...
