The brakes on my Giant Reign E+0 are really noisy, they use metal pads (gold backed) which I know can be noisy on initial bite but jeez these are so loud I can't bear it! I've swapped pads & cleaned rotors several times but they're always the same.
Is it just the pads causing this? I have read...
Hi all, Greetings!
I am new on this post.
Question- Can anyone suggest where I can purchase a 26 inch rim, 36h disc brake rim that would fit a 26.3 tyre?
It would be for all terrain type ridding- ie- road, lite mtn biking, trails.
I live in Orange County, CA.
Your input is greatly...
Hi there,
Just noticed something on my 2022 Levo alloy, between the rear brake tab and the disc there is less than half a millimeter of clearance, 0.3 from what I could measure… slightly worrying and annoying.
I blame it probably on a couple of factors: those brake tabs are probably welded quite...
I have a 2022 Turbo Levo Expert. I love the TRP DHR Evo brakes and want to put them on my Levo. The problem is that I can't get 203mm Rotor anywhere. So I ordered 2x 223mm rotors.
Is it possible to mount them on the rear? I know zero about brake mounts, but what mount would I need if it was...
Since I've had the bike, I've repeatedly had problems with screaming brakes. I've come to the conclusion that it's simply contamination. On the rear brake, I put this down to careless washing on my part transferring crap from the drive train. Both front and back brakes have similar problems...
I'm having some real trouble with my Magura brakes. I just don't feel like I'm getting the best out of them and wondered if you could give me some advice? I bled the front one yesterday as it's been just under a year since I got them - the purged fluid was black...! I've got the front feeling...
I have the stock pads in the SRAM Guides that came fitted as standard on the 2018 Levo, and all's been okay.. that was until riding in the wet the other day when they decided to act like a squealing banshee, brake power was alright but got fed up with the noise, (although was handy to warn folk...
