brose motor
  1. dar23
    Levo Gen 2 Brose blind plugs sourcing
    It was a beautiful moment having a new motor on warranty (stripped T belt). Disappointingly found zero blanking (blind) plugs on the new motor. One effing job they had - and after my enquiry returned only a shrug of the shoulders I knew I was on my own with sorting this out. For all who have...
  2. JAYWE
    Kenevo Gen1 My Brose Motor makes sqeaking sounds
    Hello, my turbo kenevo only has 650km and my motor already makes strange sqeaking sounds. I made a short video.
  3. TonyT
    Kenevo Gen1 kenevo 2019 motor second owner
    Hi ive just got a 2019 kenevo which still has original motor, so im guessing it might break, which is fine. Ive been through forums and robs youtube videos, from what i read it should still be covered for second owner for up to 4years? The original owner checked with his tredz bike shop where he...
  4. RichP
    Levo Gen 2 4973 miles before motor repair
    I bought my Levo back in 2018 and it’s exactly 3 years to the day since my first ride on it. Since then I’ve covered 4973 miles without a single motor issue. On Sunday morning my ride was cancelled due to the biblical weather so I thought I’d treat her to a clean. I only use a bucket and wash...
  5. Blebo19
    Brose s mag temperature
    Please post here your brose s mag max temperature you detected under severe usage conditions. Please also post your ebike model , km ,and if you ecperienced any troubles with motor. 2019 levo expert 300km 87° C Motor failure , exchanged because too noisy. I'll write an update about...
  6. I
    Brose sprag clutch
    Hello everyone ; I am Inanc from Turkey. I am Mechanical Engineering student. I am interested in e bikes. I am in a jam with these sprag clutch (one way bearings). How Brose's crank shaft work i do not understand. They used 2 spag clutch.How they arranged rotating directions i do not...
