I'm looking to build a lightweight, long travel EMTB using the bafang m820. This all started when I was looking to do a mondraker dune frame build but can't get the frame in Australia then got into the rabbit hole of the m820 motor and like the idea
Ideally looking for minimum of 160mm rear...
At Eurobike 2024, we launched a new E-gravel frame that fits the M820 36V motor and 360wh battery.
Experts are welcome to give their opinions and suggestions!
If there are bulk customers interested, we can design and produce similar frames fit for other brand motors for you. We also have contact...
I recently got a datasheet for the Dengfu E69 Frame Kit (for Bafang M820). Designed for 540Wh or 720Wh battery.
Seems like a very interesting alternative to the Lightcarbon LCE930 and other lightweight E-Bike builts with the Bafang M820.
Has anyone here already ordered the Dengfu E69? If so...
Hey everyone,
I am in the process of fiddling around with some m820 motors we received at the ebike shop I work at, and I was hoping to see if anyone here knows if it is possible to remove the 25kph speed limit cap?
I have the BESST box and the motor loaded into the software, but there does...
