What brakes rotor are you running?
Bob88
78
65
Hampshire
203/180 front/rear with shimano saints on sintered pads. The thought of putting bigger rotors never occurred to me as the stopping power is already phenomenal.
Nomad1
247
81
03818
I read Saint brakes have the old I-Spec B mouting, so it is impossible to attach on the new XT 12V shifter (I-Spec EV).
Solutions? Adapter? Anyone has this configuration?
Thanks in advance.
I have Saint brakes and a xtr shifter with I-Spec ev can you post a picture of your shifter? I think the adapter you need is the same one I used on mine.
Oakhills
68
35
Oakland, California
I’m going to try out the nex XTR 6 bolt rotors with my Saint brakes, 203 front and back. Right now the brakes are paired to the SRAM 9” front and 8” back, but those get a bit hot and it seemed the Saints worked better with the older, non finned, Shimano icetech rotors on other bikes I have. I hope the new finned XTR rotors offer better cooling and better stopping power that either of those two rotors I have used.
9,932
Rotors: Front - Shimano RT-MT900, 203mm Rear - Shimano RT-EM910, 203mm
Brake system: Shimano XT, 4 piston, finned pads BR-M8120, pad spec NO3A for resin (NO4C for metallic).
All as original spec, they seem perfect to me.
571K
