First of all this might sound like a vent (and maybe it is) but this is so damn frustrating.
We own 2 Merida eONE-TWENTY bikes:
- 1st one bought new in 2017 so the missus could keep up with me on the climbs
- 2nd one bought last year since I got fat and lazy , it's was almost new, had around 200km
This spring, around March, after it sat the entire winter, I've serviced the wife's bike fork, shock, brakes, etc, we're all equipped and ready to go, put the battery in, start the bike, boom! E010 on display, I didn't know but this would be the first step in the tumble down the rabbit's hole called "Shimano is kicking their own customers in the nuts". The back was out of warranty, of course, after I tried everything I found online I've sent the motor to the LBS I bought it from (not so "local", it is 250km away) and managed by a small miracle so find a 2 second hand motors and we rode all summer.
The motor came back from the LBS and the end of August, they've sent it to Shimano and their verdict was "it's dead" without any kind of other explanation and they offered me a new one for 800eur, no thanks.
About 6 weeks ago I was pushing my bike (not riding it) on some uncleared forest paths and it also gave the E010 error, it gave me the chills, but it cleared after restart, it appeared again, then it magically cleared and I've put it out of my mind.
Two weeks ago I was riding, luckily I've just climbed a hill and the bike gave the E010 error and stopped, couldn't resurrect it so I went home.
As I still had a spare motor, I quickly plugged in it to see if the motor was the issue, once that was confirmed I postponed the replacement.
Later that day I want to see what the error was and I plugged in my laptop (I have the PCE02 interface) and it had a bunch of "E01021" errors with no date & time in the log, I've forcibly upgraded the firmware (it was already 4.9.0) and the error was gone, hooray!
Fast-forward this Saturday, went for a test run, everything was fine, after about 1 hour of riding I was resting on top of a hill & taking pictures, the bike was 3 meters away from me when I heard the dreaded "beep,beep,beep", E010 again, went home, hooked it to the laptop, a bunch of dateless "E01021" and 1 "E01020" with the time and date, nothing I did erased the error.
Sunday morning I've quickly swapped the motor with the last spare as some friends came to go on a longer ride, everything was OK, rode about 40 minutes on a paved downhill I heard the "beep,beep,beep", stopped and started swearing, restarted the bike, the error vanished, after about 15 more minutes the bike stopped and it wouldn't start.
Again, home, laptop, it has a bunch of "E01021" errors with no time & date, upgraded the firmware several times, no luck, tested with the working motor from my wife's bike, it works. So I've just plugged everything back in and let it there for about 2 hrs, after that time, I wanted to remove the battery and put the bike in the garage and decided to start it one last time, and it starts ... and it works without any logical explanation.
Now I'm stuck with 2 dead motors (both with E01020 + E01021 errors), 1 motor (E01021) is working but who knows for how long, this is what I've done over the course of 6 months:
- replacement motors had NO ERRORS when I tested and upgraded the firmware to 4.9.0
- cleaned and cleaned and cleaned all the connections - NO CHANGE
- checked ALL the cables with a multi-meter and rattled them - NO ERROR
- swapped the batteries between the 2 bikes - NO CHANGE
I'm out of ideas, I don't want to spend 800euros on a new motor, I can't sell my bike to get a new one since I don't know for how long this motor will keep working or why it wasn't working, I can't use my bike for longer rides since I don't know where will it stop.
After seeing that the new EP8 motor failed when it was reviewed with the error E01020 and it had to be replaced, it's safe to say that I will not spend my money on a Shimano powered ebike anytime soon.
Thanks for reading the saga
