Crestline brings out the new and limited LS160 and S180 with Bosch CX gen5
Motor
Bosch Performance CX 85 Nm - gen5
Battery
600 and 800 Wh
Fork Travel
160-180 mm
Rear Travel
160-180 mm
Price
$9.999-11.249
Crestline says they're tirelessly in pursuit of maximizing your time spent in nature on the bike. But not all of you. The new 2025 Crestline LS160 only comes in 50 numbered units for 2025. And the longer travel S180 comes in 150 units. So, you have to be quick about it if you want Crestline to help maximizing your nature time.
Two models and a third option​
The LS160 is a very well specc'ed bike, with DT Swiss carbon wheels and 160 mm Rockshox Ultimate suspension, comes in at $11.249. That's with the new Bosch CX motor and 600 Wh battery.
If you want to maximize your chances of owning a Crestline, you could consider the 180 mm travel Crestline S180. This model that is a bit cheaper, at $9.999. An it too is a well specc'ed bike with Sram Maven brakes and Rockshox Ultimate suspension.
If your shed is filled with high end bike components, you might be excited to hear about the RS Signature frameset. Starting at $6.499, you get the CX motor, a 600 Wh battery a headset and a chainguide mounted on the frame. No suspension is included, and it will accept 160 to 180 mm travel setups. There is no info on production numbers for the frame, and shipping starts December 2025.
Wheels and geometry​
The Crestline bikes differ a bit, depending on the frame size you chose. Crestline recommend mullet wheels for the smaller of three sizes, the "RH-2". The MX setup has 445 mm chainstays. The middle size, RH-3 is recommended with either a 27.5 or 29er rear wheel. If you opt for a 29er rear, the you'll get 455 mm chainstays. This goes for both the LS160 and S180.
The bikes are fitted with a reach-adjustable headset that does not appear to affect the head angle. The LS160 in size RH-3 has 480 mm reach and 1.288 mm wheelbase in the Long reach setting. That's a long bike! Head angle is 64* for the 160 mm model and 63.5* for the 180 version.
Power upgrade?​
Many bikes get the new Bosch system these days. But Crestline is promising more than the competition. They plan on giving you deeper access into the motor settings. No, I can't imagine they'll give you access to alter the motor cut-off speed, that would earn them serious legal issues. But they will allow you to draw more power from the motor. Crestline doesn't say how, just that it will be available the summer of -25. Have Crestline actually been allowed to do their own, exclusive modifications to the Bosch-motor?
About author
knut7
Main editor at emtbforums.com and owner of emtb.no.
https://emtb.no/contact/
Comments
