- Intended Use
- Trail, All Mountain, Enduro
- Motor
- TQ HPR50 50 Nm
- Battery
- 360 Wh
- Fork Travel
- 160 mm
- Rear Travel
- 155 mm
- Weight
- 17.9-19.5 kg
The age of mild and relatively lightweight, I mean Superlight emtbs, is truly upon us. So many electric trailbikes are being introduced, and most of them are lighter bikes with less battery and power. Scott is now out with their second lightweight bike, the 2024 Scott Voltage eRide. What I find most interesting whenever a new lightweight bike is introduced is seeing which motor it packs.
The Scott Voltage eRide looks so sleek and smooth, I really like the looks of the frame. This 155/160 mm travel 29er looks very much like the Scott Genius. You’d have to be above average into bikes to tell them apart.
The Scott Genius and the Scott Voltage eRide are very much alike. Can you tell which is which? The one on the right has a motor.
I expect the lightweight Voltage will be quite nimble, but it won’t be anything like the Lumen eRide. The Voltage seems to be burly and stable. And it seems it will be available in April, at least in my part of the world.
TQ HPR50 motor
Scott picked the TQ HPR50 motor on the Voltage eRide. That’s no surprise, Scott is already using the TQ motor on the lighter Lumen eRide. This is a very pleasant motor. The motor power kicks in so carefully, almost unnoticeably. I can’t really pinpoint the exact moment when the motor engages, but as I pedal along, it’s there. And I get a good amount of help as I pick up the pace and pedal faster, in near complete silence. Read my review of the motor for more details. The battery has 360 Wh capacity and it’s fixed inside the downtube.
Motor and shock integration
I believe there’s another reason why Scott has opted for the small and compact TQ motor. Just like on the Scott Lumen, the Voltage has the shock hidden inside the frame, alongside the motor. Scott needs the small HPR50 to make this work. The lid on the bottom of the frame isn’t for removing the battery, it’s to access the valve and adjustment knobs on the shock.The Scott Voltage eRide looks so sleek and smooth, I really like the looks of the frame. This 155/160 mm travel 29er looks very much like the Scott Genius. You’d have to be above average into bikes to tell them apart.
Shock access |
Extender and bottle |
About the Scott Voltage eRide
Two of the six models are labled Contessa, which means they’re female specific. Weight ranges between 17.9 and 19.5 kg. That’s not the lightest bike in this category. But that’s not to be expected. This is a relatively long travel bike with a nice and slack 63.9* head angle. The 455 mm chainstay is another indication the Voltage is made for stability and descents. A long rear end contributes to the long wheelbase. It’s as much as 1.285 mm for size Large!I expect the lightweight Voltage will be quite nimble, but it won’t be anything like the Lumen eRide. The Voltage seems to be burly and stable. And it seems it will be available in April, at least in my part of the world.
- Voltage eRide 920: £6.099 / €6.599
- Voltage eRide 910: £6.599 / €7.199
- Voltage eRide 900 Tuned: £10.099 / €10.599
- Voltage eRide 900 SL: £11.899 / €12.999
- Voltage Contessa eRide 910: £6.099 / €6.599
- Voltage Contessa eRide 900: £6.599 / €7.199
My take
Most lightweight emtbs come with less travel, they’re designed to be light, allround, all mountain trail bikes. The Scott Voltage eRide is one of a few more aggressive yet light emtbs. And as always, these light bikes aren't cheap.
