mtnbikerva1
I am new to the bikes and try to learn about all the information provided, and how best to use an access at all. Thank you.
I run a Garmin 530 and a Fenix 6X and they both overstate watts because they can't talk to the ebike.I am writing the new pivot, shuttle AM if it matters.
The Kiox display looks just like the flow app screen, so give your phone a try to see if that's what you are looking for. It has that same ramped power display where it shows the motor watts and your watts and total watts graphically as you ride. Then if you like that data you can add the Kiox display so you don't have to use your phoneSimilar question to the OP but rather than the Flow App, which I don't bother with, I am looking at the Bosch Kiox display. On the display, if you scroll through you come across a box headed ''power' giving readings in 'watts'. Is this reading for the output of the motor, the rider, or both?
at 8:12 it talks about cadence and shows the display and talks about itSimilar question to the OP but rather than the Flow App, which I don't bother with, I am looking at the Bosch Kiox display. On the display, if you scroll through you come across a box headed ''power' giving readings in 'watts'. Is this reading for the output of the motor, the rider, or both?
