I have two Novatec XDS642SB rear hubs, 142x12 and 148x12.
The 142mm has 84 Engagement points with the 42 tooth ratchet -probably by this: "This hub uses the X4 freehub which has 6 asymmetric pawls (3×2) which gives a 4.25-degree Angle of Engagement and 84 Points of Engagement"
But the 148x12 is actually only 42(!) with the same characteristics I tried to swap the pawls but still had the same results.
Who can I get 84 POE from the 148 hub?
Cheers.
Cheers.
