need help with final qualification work
pascha__groznyj
Russia
Hello everyone, I'm doing my final qualifying work at the university on electric bicycles. Are there frame drawings for three-bolt engine connections for shimano engines, for example? I have the approximate dimensions for the engine itself in the picture.
I would also like to know how the torque sensor works. I found a patented technology from Bosch, where the load cells are on the bushing, and the connecting rod shaft simply sticks into this bushing. I think the same principle applies to shimano, or I may be wrong. If this is really the case, then it is unclear to me how the readings are taken from the strain gauges, because they rotate together with the bushing, maybe there are current-removing brushes?
526K
