beagling
The Crafty Carbon SE (Special Edition) is a mid-model year bike that Mondraker has decided to make to fill the void of bikes during supply chain issues and component shortages. Getting some of the upgrades that the 2022 line will see, the SE is one of the best spec'd bikes in its price range. With a Fox 38 fork and a Fox Float X rear shock it comes with top of the line suspension matched a SRAM GX Drivetrain, and Maxxis tires, you will be stoked with the SE. The Mondraker Crafty Special Edition is the best build available, and it is available NOW.
Motor | Bosch Performance Line CX Cruise (25Km/h) GEN4 |
Battery | Bosch Powertube 625Wh |
Display | Bosch Kiox |
Frame | Crafty 6061 Alloy Stealth Evo, e-Bike Optimized Zero Suspension System, 150mm travel, Forward Geometry, internal removable battery with integrated alloy cover, Boost 12x148mm rear axle, tapered head tube, one-piece Monoblock upper link, HHG internal cable routing, MAX capacity sealed bearings, oversize 17mm axles, integrated dropout speed sensor, exclusive plastic motor covers |
Fork | Fox 38 29 Float FIT GRIP EVOL Performance, 160mm, e-bike tuned, tapered steerer tube, Boost 15x110mm axle, 44mm offset. Settings: 3 positions with micro adjust compression, low-speed rebound, air preload |
Rear Shock | Fox Float-X LV, 205x65mm. Settings: compression 3 positions lever, low-speed compression, low-speed rebound, air preload. Trunnion top mount, 25x10mm bottom bushings |
Front Brake | SRAM G2 R, 4-piston caliper, Centerline 200mm IS 6 bolts one-piece rotor, steel-backed organic pads |
Rear Brake | SRAM G2 R, 4-piston caliper, Centerline 200mm IS 6 bolts one-piece rotor, steel-backed organic pads |
Rear Derailleur | SRAM GX Eagle, Type 3 roller bearing clutch, cage lock, 1x12s, X-Actuation 1:1 |
Shift Levers | SRAM Trigger NX Eagle, 12s, X-Actuation 1:1, single click |
Chain | SRAM NX Eagle, 12s, Powerlock |
Cassette | SRAM PG-1210, 11-50T, 12s |
Crankset | Race Face Aeffect ebike, 165mm |
Chain Ring | Spec not provided |
Chain Guard | Spec not provided |
Rims | Mavic E-Deemax 30 29, 30mm internal width, sleeved aluminum, 28 spokes |
Front Hub | Mavic E-Deemax, Boost 15x110mm, IS 6 bolts, Straight pull |
Rear Hub | Mavic E-Deemax, Boost 12x148mm, Instant 360, IS 6 bolts, Straight pull |
