Shock Mounting Bushing Front | 30x8 |
Shock Mounting Bushing Rear | 30x8 |
Thanks!!! I'll check it out.Great help!!!
Shock Mounting Bushing Front 30x8 Shock Mounting Bushing Rear 30x8
With the recommendation to have bearing in the rear shock mount:
FOX Shock Mounting Hardware Bearing Roller Full Complement 8x30mm
FOX Shock Mounting Hardware Bearing Roller Full Complement 8x30mmwww.tftuned.com
For front shock mount, select 8x30 here:
You probably also want a bushing tool (unless you already have one):
Bushing Tool for 12.7mm bushings and Cane Creek 2012+
Bushing Tool for 12.7mm bushings and Cane Creek 2012+. This tool will fit all Fox, most RockShox and Cane Creeks from 2012 onwardswww.tftuned.com
